hank
- Jan 23, 2006
- Iowa
- '16 RsVector XTX 1.75
'07 Phazer GT
'16 Phazer RTX
Thanks,
-Hank
-Hank
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I just bought a set to move sleds around the yard, maybe help with loading onto the trailer.
I back my second sled into my trailer and thought these may help
Jury is out. I used them once to unload my new sled and put on my lift. You need to make sure they are threaded all the way on.
I guess its better than driving through the grass and dirt.
I will know if they worth it the more I use, or don't use, them.
hank
- Jan 23, 2006
- Iowa
'07 Phazer GT
'16 Phazer RTX
My desired use is just to load the sled onto my trailer, mounting outside isn't an option is it is too wide but far as I can tell the wheelz interfere with the A-frame on the inside
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Ahhhh, I see your problem. The smaller wheel is still too big for the Delta Box chassis, correct?
I studied these wheels bit when I got them. If you had access to a lathe or new someone in a machine shop, they would not be hard to duplicate with some smaller wheels.
