Hauch #5 Clutch Kit
Turk said:
Your kit was made to harness 120 hp. Your apex has 150 hp. I will let you figure it out.
The question is still valid, I don't want to loose it in your quick reply, citing the obvious.
I understand that the weights will have to be different.
The remedial version of my question is; can the RX arm profile be worked with in the Apex. The springs and helix appear to be the same across all the Hauck #5's. I would like someone to confirm if they know.
Apex stock clutching is dead nutz on after 1000 miles. It makes about 15ish more hp then the rx1. The rx1 arms would work in an apex with tweaking but why???? when the stock stuff works so well? In my opinion i would leave the stock clutching alone rather then trying to make something old work in something new & improved & probably go slower.
