heat exchanger removal proceedure please
black knight
ottawa ont. canada
For those that have had to replace there front heat exchanger could you go threw the process for me please. And is it a big job? i am assuming skid track ,drive axel would all have to come out but what about hose routing is it a :o| ?
Any info from experience is greatly appreciated.
Oh boy!!!!.... i did this this past summer....
Remove suspension, axle, chaincase... everyhting!!!
need to remove rear engine Bolt... its the 18" long bolt that rubs thru the exchanger.... get a good drill.. tyhere are about 30 rivets to be drilled disconnect coolant lines below motor.....
this is a big job... I'm not going to beat around the bush. If the hole is repairable i would not remove from sled... bring sled to a good welder and have it repaired in the machine... if i had to do this again that would be the route. i only had a new rad on the shelf.
the front rad acts as part of the frame. basically its the first thing to go into the sled... and the last to come out.
