zrdude
hi, just bought an 03 rx1 , wondering is there any where i can hook the plug into for my heated visor on my helmet, also anyone know where i can download a owners manual. by the way this is my first four stroke sled , any tiops or advice would be great. A++++ website
jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
- 2010 RS VECTOR GT LTX STOCK FOR NOW!
Hello I would go directly to the battery or I cheated and went to the Jumper cables on the side of the mahcine. I used round crimp rings and bolted them to the jumper and make sure you tape over the connections with electical tape so they dont arc out. The addvantage of going direct is your helmet can stay pluged in when you stopp and rest so it doest fog or ice up. I have been running this way for 2 years no trouble.
jdp
jdp
I went to the jumper cables, witch are already fused.
A friend of mine ran straight off the battery and burnt up the wire's
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
i'm sure there is a accessories wire there so you can put cig switch in. What i did was buy the switch from a new vector and the pug was the same and plug it in. and mounted the visor switch to handle bars.
zrdude
thanks for info guys
jtman04401
I went strait to the Batt and have not had any issues at all.
When hooking to the battery remember to install a fuse as close to the battery as possible. If the wire shorts out there is less of a chance to damage the sled.
Fourcam281
No matter where I installed it I would fuse it...
