heel,verse heavy test
vcrash
muskoka
Testing heelclickers, heavy hitters and about 4 helixs tonight, will test both primary kits first with stock secondary and stock spring, give some suggeted setups for the heelclickers and heavy hitters and i will let you know how they work, stock rx1 shorty, 196 studs and 210 lb rider, snow track of at least 1 mile, will be testing against srx that remain untouched until testing is finished
I am currrently in the process of dialing in my Heelclickers. I have white primary spring with 3.4 in heel, nothing in the center, and 3.3 in tip. Goes straight to 10500 but engagement is on the high side. Have heard from others that you can run the stock primary spring w/ or w/o shims (two at most). This will bring engagement down so will be testing that along with the gray HC spring. I also have the a stock secondary but am running the Yamaha silver spring in it.
