(help) code 12 on 08 nytro
macnytro
i rode the sled last sunday it ran fine then put it in garage tryed to start it today a week later & code 12 flashing will not turn over i know it is the crankshaft position sensor just looking to see if anybody had this happen to them & what was done to fix it thanks
posted on the other forum...chances are something is interrupting the speedo cable or the area behind the clutch...where the jack shaft comes through...have had it before, uninstall and install it, and should clear it...
I forgot, I had to replace a fuse or whatever...that was what happened...it was covered by warranty, so no issue...but it is one of the ones right up in front of the oil tank...
