Murse
- Sep 7, 2012
- Cornwall, Ontario, Canada
- 2011 Yamaha Apex Std Red
Looking to adjust the engine timing chain at end of season just wondering how to do it, thanks.
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700, 2023 Polaris Boost VR-129
- Niles, Oh
Chain is self adjusting (tensioning). Just out of curiosity, what would lead you to believe that it needs adjusted?
Murse
- Sep 7, 2012
On start up when it is cold after sitting a few days for a few seconds I hear a small rattle which I assumed was a chain rattle. I am not too concerned just wanted to know as preventative maintenance.
Might be valve noise...
Murse
- Sep 7, 2012
Ok good I can live with that. Thanks.
scott32
- Jan 12, 2009
- huron county, ontario
- 07 Apex RTX se, 09 Nytro XTX
Clutch rattle, exhaust clamp rattle, any other things, loose rivets etc. I can't see the timing chain being the cause of it. If it is hard starting or running ruff, maybe a valve lash adjustment. But to cause a rattle..hmmm. I would look everywhere else first before I turned to internals. Regular oil changes and proper filters these babies are pretty much bulletproof.
Murse
- Sep 7, 2012
exhaust done last season with copper donuts and there is no sound of exhaust leak and believe me I know that sound. Clutch rattle hmmm perhaps I will have to look into it further. I have a squeaking but I smoke my belt a couple of times this season so I am not concerned. The sled runs perfect always hitting 110MPH plus on any trail condition so really I am not too concerned was just planning ahead things to do before putting sled away for next season. Going for a 3 day saddle bag trip should be good sled has been running the best it ever has this season 19300km's and counting.
scott32
- Jan 12, 2009
Exhaust heat shield. As long as your positive that nothing has come loose. Gas and go, Ride on...
Murse
- Sep 7, 2012
Right on!
patdalr
you may hear the valves more if they are needing reajustement (valve clearance)
manual says to check them at 40 000km
