Mercer5
- May 31, 2007
- Wales WI
- 2014 Viper, 2001 SRX, 1990 Sno Scoot, Kitty Cat
I need all 3 axle wheels and thought I had the solution until I found out I need the 6004 bearing instead of the 6204, Yamaha is out of stock on EOM ones and I can't find anything aftermarket. I am not spending $90 on the billet ones from accessory catalog. We are leaving for big ride 2/20 so my time is tight.
Can anyone let me knwo what part numbers I can search for either through PArts Unlimited, Bell, or ????
HELP !!!!!
Jim
HELP !!!!!
Jim
yamaouch08
- Jan 17, 2006
- Otisville,Michigan
- www.chapmanssports.com
Call Kevin at Port Yamaha at 262-377-5480 he usually has the Yamaha accessory wheels in stock I went with the black spoked wheel myself. heres the link to the wheels I am talking about:
http://www.portyamaha.com/eshopprod_cat ... _Wheel.htm
ScottyD
- Mar 2, 2008
rt chassis mach Z 05-07 rear wheels take a 6004 bearing and is the same wheel dia.
danq
I'm confused. The rear wheels (3 that the track wraps around) use a 6205 bearing I think. Well, the center one does, the outer ones don't have replaceable bearings if I recall correctly. yamaouch08 gave you a good alternative for those 3.
The 6 small idler wheels use the 6004 bearing if you have the accessory wheels. If you have original idlers, they don't have replaceable bearings at all. Get these as replacements: http://www.portyamaha.com/eshopprod_cat ... er_Bog.htm
The two large upper idlers use a 6205 bearing. I just did those last weekend so I'm sure of that bearing.
