Help with Belt Install
penetang guy
I can't figure out from the manual how to install the Vbelt in my Attak. How do I move the secondary sheave closer to the primary sheave? Any idiot instructions on this? Thanks if you can help... it says turn clockwise and push towards the engine. I'm a pretty big guy and I can push and turn and nothing is giving.
Grab the belt between the two clutches and pull up, While pulling push in on the cam on the driven (rear) clutch, Cam is the thing that the three nut's hold on and it will open. To put the new one on, put the belt on the front clutch and hook it in the rear clutch on the top and while pushing in (down) on the belt also push in on the cam on the rear clutch and as it opens work the belt around and on. When you push on the cam it also helps to push in and clock wise at the same time. Also after belt is on either work the belt or raise the rear of the sled and run it to get the belt back to the top of the rear clutch or it will burn the belt when trying to take off. You can pop a belt off and back on in second's if done wright. Don't leave home till you can do it, A belt can go at any time and leave you out with the wolf's. LOL, kviper
Thank you kviper, that was easy! No indication in the instruction manual about pressing where you said. Took me less than 15 seconds once I figured it out - as you described! Thanks!!!
Just like a woman, You need to know where to push and where to pull. LOL kviper
Easy way to get the belt off is to hold the brake on and pull up and forward (towards the front of sled) on the belt. That will spread the sheves and then just work the belt off.
Put it back on like Kvipre said.
