track has about 1 inch of slack when pulling down 22 lbs with a tension spring. I think you are right that the drivers may be a little to the right of the clip window. What do need to do to center it, i probably need to remove the chain case cover and left side bearing collar lock in order to to center the driver , correct. Thanks
