Here is what I have had...goofy electrical stuff...UPDATE
SIMMER
Niagara Falls, NY
All of this happened over the course of 2 day ride...
Speedo shut right down on me twice while riding.
High Beam/Low beam reversed (High Switch = Low.... Low Switch = High then after I shut the machine down it went back to normal... :roll: )
Fuel Guage when Full shows everything EXCEPT FULL...fluctuates all day long.
Going into the dealer tommorow...dealer thinks it might be harness problems either under the toolbox or beside the motor on the MAG side. There is head bolt on the MAG corner of the motor that can rub the thin plastic wiring harness attached to the frame. Check it out...mine is definately rubbing but what damage if any has yet to be seen.
Checked EVERYTHING...and all of the above turned out to be a bad connection to the SPEEDO at the back. I guess there is a retainer clip that was not positioned properly and this caused everything to screw up..... :roll:
Wheewwww!
