kokonut
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
I like that
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
What rear shocks did you get?
kokonut
not sure
of the part number...my stock shock froze and with some advice from here Yamaha warrantied.....They came up with different part number than stock will find out and let you know
radianguy
- Jan 1, 2007
- 2009 Yamaha FX NYTRO XT Express
Looks good! I just did my tunnel yesterday, how did you do around the decals on the tunnel? Did you cut around them?
kokonut
m
yes,I used "green" tape and very carefully cut around them 2 days later to remove.I did not "tape"decals on other side and 5 coats later can still see them
wshellrider
looks great! Where did you stop on the running boards? Looks like the outer tube is not painted.
kokonut
X
Did not do running boards at all. Am worried my feet would tear up plasti-dip
wshellrider
Can you post a pic of how you ended the color before the running boards? I would like to do something similar.
kokonut
pic
All I did was tape it all off like a car,and when it cured and I removed tape sprayed it with clear glossifier and faded in to running boards so edges don't come up.P.S. Make sure you cut along edge of tape before pulling it up....and plasti-dip is dry.Trust me if you don't it will pull up and you have to redo..I learned the hard way....lol
stubb111
very nice..... I LIKE IT
dremmick
what kind of prep work did you do before you applied the plastidip?
srxpert
What type of plasic-dip did you use? Was It a brush on or spray on? A picture or part number would be great. Thanks Shane
why not just paint it works great last for years
apracing
- Feb 19, 2013
- new brunswick
- 2004 rx1 warrior 2006 apex gt 1979 enticer 340
nice job ..looks good !
