Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Last year at 50 miles my finger track had really stretched and it ratcheted horribly. At 60 miles on my warrior it doesn't appear to have stretched at all. Both sled are studded. Does the Ripsaw stretch less?
JDKRXW
At 300 miles I tightened the adjuster bolts 1 full turn each because of a little bit of ratcheting. ~500 miles now and everything is still good.
BIG BLACK WARRIOR
I tightened my track up at 250 miles. Now have close to 1200 miles, and it has not stretched anymore.
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
I have 1100 miles on mine, and I have adjusted it twice! It ratcheted when I first drove it, so it was not properly adjusted from the dealer, so it would be more accurate to say that it has been adjusted once, and it has been fine
No oil usage yet either 8)
192 Woodys
I stretched mine doing holeshots and speed runs for 30 miles, took 3 adjusts but no sign of stretching since
jim-bob
Last year on the shorty and 6000 miles I adjusted once/ on this Warrior in 800 miles I've done it four times/ Seems last year it was a complaint and a lot of notes were made about it/ I dont know if it's become the norm- therefore no one is commenting on it or the problem has gone away for most/ later
monker
About 350 miles so far. Tightened once aroun 100, again around 150, but probably didn't need to. Loosened it a little this morning. I'm also running 189 studs so I wanted to make sure it wouldn't hit.
DIwarrior
- Oct 22, 2003
- Drummond Island MI
- 2025 SRX LE #473
2025 SW XTX LE
2025 SW LTX GT
2001 SRX
1968 Ski-Doo
- Drummond Island, MI
- Nope
A little over 600 miles so far. I've had to tighten my track 4 times. The first 2 times tighter by 1 full turn. 3rd. time 3/4 of a turn, the last time 1/2 turn. The last time it would ratchet occasionally when accelerating hard over small trail bumps, so I think this will be it. It does need to be much tighter than what I normally (used to) run.
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
Two full turns for me at about 300 mi. Maybe cause I got a turbo on it? Still ratchets a bit in the midrange. Will check again this week.
Silver
I have 700 miles on my Warrior and have adjusted it twice once after 150 miles (4 turns) and put one more on yesterday.For a total of 5 turns.
