Hwo much could I get for this?
  • Thread starter Thread starter Anonymous
  • Start date Start date
A
Anonymous
2006 Apex mountain
550 kilometers
9.25 inch powermadd pivot riser 9.25"
Steering mounted fog light in place of headlight
Relocated dash
Pingel killsw
Electronic engine unit/regulator/harness relocated in center of sled
Rear trunk mounted battery
Mountain mod front turbo mount seat
Challenger extreme 174 x 2.5 x 15
Custom made tunnel (crossover from M7 and stock apex)
Complete datalogger with air fuel,rpm,boost, tps and ready for knock sensor input)
Steering pod mounted analog/digital air fuel and analog boost gauges
Boondocker hiboost et Powderlites hi boost (Good up to 30psi)
Big injectors kit (boondocker)
Micro-belmont reactor 4 ramps clutch
Hyperlite roller secondary
Lefty powermadd
Bellypan/suspension protector plates
8 inch wahl wheels
2 rear wheel shaft kit
Hyperfax
Anti ratchet wahl
Titanium sprocket shaft wahl
Turbo GT2860RS boondocker
Fuel pump MSD
Knock sensor Parker motorsports
Tunnel/anti slip reinforcments
Rear M7 rack and light
This stuff costed me a bit over 36000 Canadian dollars + install time
And a few other goodies I may not remember off my head
This is getting way too expensive for me so I need to sell it....
How much can I get for it?
Price
I really don't understand the logic on this one. You already have everything done. The outgoing cost should be about done. Now you want to sell it??? Get ready to get kicked in the nuts.
Keep it and have fun for a year or two and then sell it and take it in the nuts. You will probably only get about half of what you have into it. Might get lucky and get more from a motivated buyer.
Good luck.
I would keep riding it and enjoy it too. You will never recoup the initial costs just the way it is.
No where near what you have into it. Especially seeing that it will not run right. You maybe should have sprung to have a pro install done.
I will get it professionnally finished this week and it will run perfectly right after that... but then... will be time to sell it for me....
sled
why is it not running correct. and it sucks but the reality is it is only worth about $25000, if in good shape. keep it and ride for another year at least.
Is this the one you had all the trouble with on the Dyno that won't run?
Yes... and now that its gonna run and scream, I am ready to give up on this project.
