shanksRX-1
- Feb 6, 2006
- Pennellville, NY
- 2010 Apex
- Pennellville, NY
Im trying to figure out why this grizzly wont start. I need the stock carb specs if anyone has them. Fuel screw setting, jet sizes, and clip position. Thanks...
gunny
- Apr 1, 2008
shanksyamaha, did ya ever get the info ya needed on the carb ??
I have a service manual for an 02 - 03, & they don't have anything on the questions you asked .....
However ...
Fuel Screw setting ... are you talk'in the air/fuel mixture on the bottom fron of the carb ?? ... If so, turn it in slow & easy until it bottoms out ... then turn it out two and half turns to start. (I set mine at 2 1/4 turns)
Jet sizes ...
Main Jet - Not sure what the altitude is where your at, I live at 5200 ft above sea level & the dealer installed a 145. You could start with a 150 if you have it.
Starter jet ... mine is a 55
Pilot Jet ... stock was a 40
Those are your three main ones. Do you need others ??
Clip position ... if you have a needle with more than one groove ... stock is the third groove counting from the top of the needle.
Another way to go is with a Dyna-Jet kit. Comes with several new main jets (they are numbered different than stock Mukini jets), a new needle & clip & a new pilot jet. If you buy it from the dealer, it SHOULD come with jets & parts for your altitude. They run about $70 I think.
Later ...
![Rockon :Rockon: :Rockon:](/styles/default/xenforo/smilies/rockon.gif)
However ...
Jet sizes ...
Later ...
