Gilbey
Well, I need some help diagnosing here. I'll tell you what the sled is doing, and they'll I'll tell you what it's not. I'm thoroughly confused, and currently my sled is pretty iced up so it's tough to diagnose. It'll be in a heated garage by this afternoon, which will tell me more than I know right now.
This thumping sound almost sounds like it's coming from the clutch side, secondary area, I can feel the thump.....thump.......thump......thump, so it's in time with the revolutions of either the clutch, track, or drive
So, here's what it is not:
Belt, same effect
Checked drive shaft bearing and jackshaft bearing, ok
Primary, ok
Secondary, not sure, but don't think so unless the shaft got slightly bent, but don't know how to tell this
Rear skid appears to be lined up and solid, a lot of ice build up though, so after some heat might know more there.
Chain case has oil stil in it, and no leaks indicated in the bottom.
So, I haven't checked the whole track, so this is what it COULD be:
Torn track at some point whacking the tunnel
Ice chunk that somehow didn't get kicked out for 16 miles
Bent drive?
Anybody else have this happen. I could feel the thump with my left foot in driving position. Felt like the drive lugs to me, or track got off, but all the lugs appear to be there.
Belt, same effect
Primary, ok
Bent drive?
