snopro442
- Dec 10, 2007
- neenah wi.
- mod 08 nytro, 2-2007 phazers and a 2010 sno pro 500 speedwerx exterminator. new 2014 nytro for towing the snowcoach. 2015 Viper mpi turbo
I just installed the rsi race bend bars and a rox 5 inch pivot riser on my 08 nytro, how should I run the throttle cable? I also have the large rsi bar pad, any help or pictures would be a great help, thanks
Zakre
i had to run teh throttle cable on the backside(closest to the rear) of the riser/relocator. More than enough slack left in it. I have the QFT relocator and a 3" riser so its probly about 5.5 inches above the stock bars.
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- SXV Venom, RTX Nytro, SR Viper RTX SE
- Maine
Not sure about that height guys. I put in 4" RSI and throttle cable free play was getting tight. You may need to order a longer throttle cable.
Zakre
the MTX cable is 2 inches longer, you can move the way the cable routes under teh hood if you need more slack before goin that route.billymx815 said:Not sure about that height guys. I put in 4" RSI and throttle cable free play was getting tight. You may need to order a longer throttle cable.
