stamminen
- Jan 22, 2014
- Grand Rapids, MN
- 2008 Apex GT
Does anybody have install instructions for the tall OEM yamaha windshield?
I'd like to know, how/where to install the support bars.
One end of the bracket goes to the Phillips head on the left side of the speedo and the other end of the bracket goes to the last outside screw on the windshield. You do the same for the opposite side.
stamminen
- Jan 22, 2014
- Grand Rapids, MN
- 2008 Apex GT
No drilling is required?
FRANK
- Dec 21, 2006
My 2006 Tall shield braces had to be mounted to the tank shroad (Yes Drilling Required) and no you can-not run without them over 50MPH, shield bends...The design of the 2011 was different with braces mounted to side. No drilling, so your 2008 requires drilling. No template required, just set it up and position bars, mark spots and remove tank shroud, drill and mount bars, re-install and connect to shield. Good Luck
