furg69
Wondering if theres a small up grade for the 180 MPI super charger , I thought I seen you could run this kit to 220 hp with some added mods. Also now being supercharged will I gain any extra with an exhaust system ?
tmk50
MPI sells a stage 1 upgrade kit for the 180 kits. Both are around $1,000.
A skinz muffler gained 8hp on the dyno on a 180 kit.
You will gain more with an excell header also.
matt@mpi
- Feb 10, 2011
Stage 1 upgrade kit for MPI Yamaha 180 kit
This kit converts your Yamaha 180 kit into a true Stage 1 kit. Includes everything you need to make the upgrade. By upgrading your 180 to a stage 1 you can run more boost over the base kit. This kit is an easy bolt on to the stock 180 kit.
TURBO
MTN-1100 $1095.00
The Turbo upgrade includes:
New high flow intercooler
Dual sided waste gate
Stiffer Blow off valve spring
New aluminum charge tube
All the necessary hoses and hardware
Re-flash of your stock GEMS controller
SUPERCHARGER
MSN-1100 $1195.00
The Supercharger upgrade includes:
New pulleys for high boost
Cold air kit
TURBO
MTN-1100 $1095.00
SUPERCHARGER
MSN-1100 $1195.00
Cold air kit
- 6K
- 7K
