RX_rider
hey, i still got a stock breather on my 04 warrior and i was thinking about puttin the K&N filter on er along with holtzman springs and changing the mains to 165. anyone else try this or just the k&n filters. just wondering if it works any good.
p.s. what other minor mods works good? high performance spark plugs? clutch kit?
BURMAD69
Works awesome put on the ECP kit you wont be disappointed.
jimmie d
I had on my 03 not putting on the 05 as a lot noisier, nice noise, but louder. Good performance though.
Jim
Jim
RX_rider
right on. i'll give er a try.
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
I put this on another post, but here it is again in case you did not see it
This set up works great on my 04 Warrior and did not cost much and it cranks
Here is what I have done:
Primary Clutch: OSO spring, 14.5 mm rollers
Secondary Clutch: Silver Spring @70 degrees, shimmed with 5/16 lock washers.
Engine: 4 TPI valves with 160 main jets, Green Holtzman Springs, NGK CR10EK Spark Plugs
Track: SLP anti-wear pads.
RX_rider
does that pully on mountian perfromance work any good?
