LIMITER STRAPS
RED800
rome ny
my rtx just broke 140 miles on the way home it felt like my limiter starps were way loose(never touched them) in the stutter bumps i could here something slapping,my transfer is 2 lines down from max(gonna turn it down) got home and noticed alot of snow build up in the front suspension,should i tighten up the limiters 1 hole or would the build up cause this....gonna turn down the transfer to just under standard..will this be the cure or should i do both..dont wanna loose to acceleration
I would certainly try the tranfer rod first....Than if you still feel like you are retting to much ski lift I would do the limiter straps 8)
