looking for step by step
Just got mine done today on my 09 RTX SE; my old ones were in brutal shape now that I see them. Had the shop do it b/c I didn't have the time & was skeptical about doing it myself. Just under $100. Good Luck
Just installed the Ulmers Kit this past weekend.
I just pulled the plastics, removed the shocks, disconnected ball joints, and removed a arms. The new bushings are a very very tight fit. If you dont have one, you should look at using a press to install them. Thats what I did and all went well. Dont think I would want to be beating my new bushings with a hammer.
The whole process is quite simple. Remove plastic, remove front suspension, remove old busings, install new bushings.
Saw or press them out. I had to cut the old plastic bushing out with a hacksaw blade. Hopefully I dont need to replace these anytime soon because I'm sure they will be a bear to get out. Pressing them out would even be a chore.
When installing new bushings some threaded rod, washers and nuts can be a decent substitute for an arbor press. Do one bushing at a time and make sure the bushing is aligned with the bore.
I'm more concerned with getting them out as they seem to be really tight. I had my steering knuckles powder coated and some got into the bushing so they need to be replaced. What is the best way to get these bushings out?
I have but the collar sitll feels tight. My skis don't move up and down freely aroung teh ski knuckle. If my sled is up on a lift and I pick up the ski;s they stay up and dont' fall down. Is this ok? I figured bushings are only $5 why not replace them. While they are out I could regrease the collar inside as well.
This is what I did.
I also had the bushings in the freezer for a day before I put them in. Along with that, I put a small amount of grease on the outside to help them slide in.
In the pic, you can see the bolt I used to pull the bushings in. Big bolt with a big nut.
Whatever you do, DO NOT use a hammer on the bushings. Watch my buddy do it, after I told him not to, and it buggered it up enough that the shaft didn't rotate easily.
