doggin303
I would like to put 162 studs down the middle on a warrior. I will probably have to add more studs later due to the turbo I am installing this weekend. If anyone has a good pattern or even other ideas on studding, let me know.
I have a template from "Woody's which allows you to stud the pattern you are looking for (i.e. 162 down the center). It wooks great, I did it to my Warrior. If I had it right now (i.e. template) I would take a picture of it to show you which holes to use, but my buddy is using right now to stud his sled and he lives 2 hours away.
It is snowing right now.......I could jump on my sled and go get it right now
Later........
Later........
jimmie d
Go to the Woodys website.
Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
Use the search feature and look for "stud patterns". There are at least 5 threads on this topic. Look also in the tech tips as I believe Mr. Sled posted one included pics of the procedure.
Chris Velardi
- Feb 3, 2004
- Killington Vermont
- www.velardi.com
Woodys recomends 162 studs (down the center) stud length for the camoplast ripsaw track is 1.325" , the design is a 2/4 patern or their template 192 guide (double & Singles) but you eliminate the outside studs {this would equall 144 on a 121" track on a 136" track it's 162} I used all single square backers on all studs instead of the doubles.
