SMOKNZ
I have been looking at doing some upgrades to lessen the hyfax wear as I have to run alot of roads to get to the trails. Was wondering what setup would be better, the Pioneer Performance wheel spacer kit or the yamaha Marginal snow kit. Also what would the benifit of adding a small wheel kit to either of these 2 setups do?
Bill
Bill
SMOKNZ
http://pioneerperformance.net/ Check under the rear suspension link
No one has any experience with either kits?
can i ask what sled we are talking about?
i have the yamaha one on my war and it did help but what helped the most was sucking up the front limiter straps 1/2" from stock settings. going onto my 3nd season with a cheap set of kimpex plastic. brother has a set of yamaha wheels on his viper as well and we have found that the bearings need to be changed every season in them. pioneers look to be aluminum so they might be better as they wick the heat away from the bearings.
apltx08
The YAM fit nice and their also fairly sturdy...this kit is for a APEX/ATTAK in the 1st link 136" track you also have kits for 121" in the 2nd...I've also linked my set up of YAM marginal on my 136" w/pics last link.
http://yamaha-motor.ca/accessories/acce ... model=2850
http://yamaha-motor.ca/accessories/acce ... model=2847
Traildemon
wheel spacers
I ran the Pioneer wheel spacers last year with good results on an 03 RX. (pro action ) I may be interested in selling them as I am swapping to a monoshock .
03turbo
what would you guys say if i have a HOLZ rear end on my 159 rx1 turbo? should i do extra wheels or what?
SMOKNZ
maim said:can i ask what sled we are talking about?
05 Warrior
i would say put the cheaper of the 2 kits on and suck up the front limiters 1/4". then try it. if the snow sticks/stays on the rails you have it set perfectly. that was the sign that mune was set right.
