jeff_yam
- Oct 6, 2010
- Quebec
- 2016 Viper LTX-LE
What is your RPM at WOT?I have COTC primary set up with 4.5g in the tip only 2 glide washers . Just factory ecu flash update
bleedyamaha
- Sep 28, 2013
- Northern Iowa
I can't remember if it's 9250 or 9150. I have a video on here making a long speed run down a snow packed road. Its under Top speed runs N/A page 4. Can't see rpms though.
jeff_yam
- Oct 6, 2010
- Quebec
- 2016 Viper LTX-LE
What is your helix? 46/40?I have a different helix and xtx gears in my sled. Pulls hard to 95 tops out at 107 wot !!!
Which primary spring do you use? Gr-wht-Gr?
Envoyé de mon Galaxy S5 avec Tapatalk
bleedyamaha
- Sep 28, 2013
- Northern Iowa
I am running a 45/41 and gwg primary spring 8fps 4.5g in the tip glide washer shims and 21/41 gearsWhat is your helix? 46/40?
jeff_yam
- Oct 6, 2010
- Quebec
- 2016 Viper LTX-LE
What is your engagement rpm?I am running a 45/41 and gwg primary spring 8fps 4.5g in the tip glide washer shims and 21/41 gears
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Your killing me lol I was thinking it was 2800 to 3200 don't quote me for sure maybe 3800 it's a little jerkyWhat is your engagement rpm?
