bucknaked
- Jun 21, 2007
Hey guys I have a 2007 McX Apex that was running great on Friday but on Saturday morning it would sputter and fall on it's face, I was able to ride the rest of the day as long as I turned my boost all the way down(7.5#'s) it felt similar to when I blew off my intercooler but I just ran a leak test today and there are no leaks. Thoughts? Maybe McX box is bad. Saturday morning it wouldn't idle and was throwing a code 14, I pulled the plug out of the McX box and noticed some corrosion, we cleaned it up and it idled and ran fine until it would go over about 8 -10 lbs. Any help would be great, thanks.
bucknaked
- Jun 21, 2007
I just unplugged the secondary injectors and tested the sled and received the exact same results, is there a way to test if this is a problem with the box or a bad connection somewhere else?
Jona$
Master
- Sep 27, 2010
- Northern
- Sweden
- Tapex/sks 800 -16
how did this end up?
gas n go
I am experiencing a similar situation. 7-8000rpm 9-10lbs boost backfiring and falling on its face, changing all my vacuum lines tomorrow night, ensuring all connections are sound, if this fails guess fuel controller is going for a reflash.
- 13K
