MCxpress Apex Vid of climbing wheelie Wyoming
Nice whats the setup in primary/secondary.
To tell the truth I haven't changed it since I bought it with 1000 miles on it. Set up by Cooke City Yamaha in 2008. Front has supertips in it/not sure what spring. Rear has stock apex helix/not sure of spring. Should I change?
If it Works and You like it so no, just curious.
It seems to work good, but am open to suggestions? Thought about a shockwave helix? Do they help? Am having trouble with it ideling when cold starting it. After a few minutes of holding the throttle lever barely open it idels and runs fine.
run 66g polaris weights and pins grind the tips just a but so they clear with a yamaha orange primary spring and 3 washers cut 30 thou. off the primary sheaves run a multi angle shock wave helix with 60 thou. cut off the end 1 turn out and a black yellow spring and hang on best clutch kit ever this apex rocks runs 10800-11000 depending on conditions ----2006 Apex GT
