Mid speed lag?
MS-310
Nashville MI
Website
www.grantswoodshop.com
Well my 05 rx1 now has a mid speed lag bogg or whatever you would call it. It does have a ECP kit, I cleaned the carbs just before i ran 900 miles last week end. It seems really stranges, full power no problem just mid range it kinda has a lag to it now? I did get it kinda warm in the up but not boiling or anything? Any ideas? thoughts? Is ther a mid range jet that could be pluged up? Thanks again
I would start with the carb cleaning. I had to do mine three times this year. The Pilot Jets affect Idle more than they do Mid-range. But, they still have a slight impact on the mid-range.
The power jets do impact Mid-range. They are larger than the Pilot Jets. But they still can easily plug up. But, ...
On mine after cleaning them twice, a main plugged up. It was like I lost a cylinder. So, you probably should look at all the jets.
Set the Fuel Screws to 2 turns out from the bottom. I attached some tips.
You did not mention and ECP Kit nor do you have it in your signature. IF the ECP Kit says more turn out on the fuel (Pilot) screws, then follow their instructions for the fuel screw adjustment.
