I know there is a thread on putting Mtn skis on an Attak and Favarcat listed part numbers that you will need for the conversion. While looking up the part numbers I notice that the PN for a 2013 Apex spindel and stopper pad were different then for a 2010 Apex Mtn.
Has anyone put Mtn skis on a 2011 - 2016 Apex? if so, can you let me know what additional parts are needed or if you fabricated your own.
blade072
- Jan 12, 2008
- Jefferson, Ohio
- 2012 Vector LTX
I have Curve skis on my 2011 Apex. The shape of the ski and the extra width really works well.
they are installed on my 2011 xtx right now. you need to use the xtx spindle rubber with a 1/8"-1/4" shim at the rear but otherwise all the parts to put on apex/attack/rx1 all work. i have all the bolts, spindle bushing and spacers from the apex mtx on mine as my brother had tried with spacer washers before and ended up riding home on one ski because of a broken bolt.
usually run curves on mine and they do float the same but the mtx keels dig in better in the sloppy stuff and the powder. besides put the curves on a different sled to fix an issue it had.
