Scooter6901
Hi,
Can anyone tell me how to change from MPH to KPH on an 07 Attack GT ?
I just purchased one from another member on this site down in the states and brought it back to Canada. Took her for a rip the other day and while I am used to seeing triple digits -- it is usually in kilometers per hour. Ripping through a field and realized was at 100 MPH. Will get used to it if it will not change but would like to switch it. Machine did not come with a manual.
I did a seach and found :
1) Turn on Power
2) Make sure it is in Odomoter Mode.
3) Press and hold select for 10 - 15 seconds and it will switch
That was on the Phazer site and I went out last night to try it -- it did not work. Is it different on the Attak ?
Thanks,
Scott
1) Turn on Power
Thanks,
Scott
yamahahaha
hold reset button I think,
Scooter6901
I actually think that I tried holding all three separately and also together for a number of seconds ( Mode, Select, Reset )....... did not notice any change in the speedo.
I will try it again tonight though !
The Artist
with engine running and sled stopped on ODO press the select button and hold for 10 sec
Scooter6901
Thanks Guys,
I must have been hitting the reset button and not the select button.
Went home at lunch and it worked just like you said it would.
Thanks Again !
Thanks Again !
