Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
MaxSpool 16sm
Dalton Qay-70
Stock primary spring
Dalton B/O sec. Wrapped 6/2
G Force Redline belt
Am I to believe that the Qay-70 weigh in at 70g empty? (No scale)
I see on TD's chart to start at 72g and wasn't sure if group could possibly shed light on this, based on your personal experience. Just to get me a bit closer to a starting point.
Ty..... Joe
Dalton Qay-70
Ty..... Joe
tsiceman
Mine:
Powertrail, stock springs, performance muffler, no cold air, xs belt. I had 1/2 &5/8 bottomed out approx 74.4 grams
Doc Harley
- Oct 17, 2016
- Here & there
I thought you'd be running a touch lighter with XS belt. I guess it would depend on which performance muffler.Mine:
Pretty sure the "stock mod" muffler doesn't do extremely well vs "SQ" or other. The later probably command a little more weight.
Doc Harley
- Oct 17, 2016
- Here & there
Looking at the chart I suppose my options are limited to
1.9g, 2g, & 2.5g
1.9g, 2g, & 2.5g
justinator
Start weights empty with that belt. TDs starting points are using 8JP belt. I dont have experience with redline belt but was told from reputable source it runs similiar rpms if not a bit lower rpms than xs belt. I would ditch the stock primary spring for yamaha blue-brown-blue or dalton blue.MaxSpool 16sm
Dalton Qay-70
Ty..... Joe
Doc Harley
- Oct 17, 2016
- Here & there
I see the blu/brn/Blu has a lower start rate & higher finish.Start weights empty with that belt. TDs starting points are using 8JP belt. I dont have experience with redline belt but was told from reputable source it runs similiar rpms if not a bit lower rpms than xs belt. I would ditch the stock primary spring for yamaha blue-brown-blue or dalton blue.
So it's going to move earlier on start and hold rpms a little higher in the rpm band. Is that correct? What will that help me to achieve?
Note: bought a Blu/wht/Blu some time back. Would that be an ok substitute for Blu/brn/Blu? Just asking.....
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
I would also buy a scale; they are cheap and are invaluable when fine tuning your clutching.
Doc Harley
- Oct 17, 2016
- Here & there
I bought the wrong one. It only reads to the closest gram. Not milligrams.I would also buy a scale; they are cheap and are invaluable when fine tuning your clutching.
Fleecer
- Jun 13, 2014
- 2019 SRX
MaxSpool 16sm
Dalton Qay-70
Ty..... Joe
I would start with empty weights. The redline pulls 100 rpm lower than an Ultimax.
You don't mention helix, but if your sled is 19 or newer, and running stock 35/39, adding tip weight in the Dalton's will make it tough to maintain rpms at topend. IMO you will fair better with straight 35 helix.
Doc Harley
- Oct 17, 2016
- Here & there
Stock 35° helixI would start with empty weights. The redline pulls 100 rpm lower than an Ultimax.
number1kyster
I run stock weights, stock secondary spring, blu/brwn/blu, MS16, stock intake, stock map sensor. Mine spins 9,100.
I did just fix some major boost leaks. We will see if that makes any difference.
Doc Harley
- Oct 17, 2016
- Here & there
Which belt?I run stock weights, stock secondary spring, blu/brwn/blu, MS16, stock intake, stock map sensor. Mine spins 9,100.
Working on these intake clamps is killing me. No b.s.
1.5 to get to pic
1.5 to find lost bolt & fuel rail spacer
1.0 to think about things...
4hrs total and haven't loosened the clamps yet. Lol
justinator
The factory spring is awkward, its quite long and has a low finish force to it. It can bind and some guys had them break as well. The blue brown blue may lower your engagement a smidge but nothing drastic. It will also help hold better rpms up top especially if you introduce some tip weight into the daltons. The blue white blue isnt a bad option either if you have it already. It will engage a little lower than blue brown blue and is a little softer up top but its a short spring that wont bind or break so better than stock spring.I see the blu/brn/Blu has a lower start rate & higher finish.
Doc Harley
- Oct 17, 2016
- Here & there
What belt are you running? Lol...The factory spring is awkward, its quite long and has a low finish force to it. It can bind and some guys had them break as well. The blue brown blue may lower your engagement a smidge but nothing drastic. It will also help hold better rpms up top especially if you introduce some tip weight into the daltons. The blue white blue isnt a bad option either if you have it already. It will engage a little lower than blue brown blue and is a little softer up top but its a short spring that wont bind or break so better than stock spring.
I'll order the Blu/brn/blu
number1kyster
XS825Which belt?
1.5 to get to pic
