rnoonan
- Feb 6, 2009
- Crystal Lake, IL
- 2007 Phazer FX
Over the summer I regularly take out my old 07 Phazer FX and start it up and run it for a bit. Everything has been working fine and it starts right up until this last time. When I turn the key to the on position, nothing happens (guage is dead). Turning the key further to try to start also does nothing at all.
I figured it must be a dead battery, so I replaced the battery but nothing changed. I then checked the fuses and all fuses were fine. I checked to see if I had 13.6V at the input side of the fuses and there were a few that didn't seem to have voltage on the input, but I didn't know if that was normal or not. The fuses that had no voltage were: the Headlight, Signal, and Auxiliary DC jack. I did try those with the key in the off, on, and start positions.
Does anyone know if those results are expected and any advice on what kind of things I should check? I know electrical problems can be tricky, so I'm hoping someone has some experience and can at least point me in the right direction.
Thanks,
Bob
Thanks,
Bob
rnoonan
- Feb 6, 2009
- Crystal Lake, IL
- 2007 Phazer FX
Please ignore the above. Embarrassed to admit it, but I never checked the kill switch and it turns out it had gotten pushed in by mistake. Really dumb, I know, but I did not expect the kill switch to prevent the gauge from working. I thought it simply prevented the engine from running/starting. So when the gauge didn't come on, I thought it was a much bigger issue.
Hopefully nobody wasted any time thinking about this. Thanks.
lol been there done that. was going to be one of the things i was going to tell you to check.
