Need a starting set up for heavy hitters
Rx1M5
Calgary Alberta
I have a set of 48 gram base weight heavy hitters that I want to put in my rx mtn. The sled is geared 19x42 with 8 tooth 3.0 pitch drivers (roughly the same dia as 2.52 9 tooth) and 162x16 maverick track. Any starting set ups out there which could save me a little tuning time?
Thx Rx1M5
1/2" allen in heel, 3 grams, 2 grams tip with stock primary & secondary settings. Should be close for 4-6k elevation.
Thanks. I should have posted we ride mostly 6-8000'. What would I need to change for that elevation. Less tip weight? Here's a sled pic. Mesh hood en-route soon.
Rx1M5
Try above set up & see how close that is. The 3 grams should be inner hole but i guess you figured that out.
OK thanks I'll be getting out next week and will let you know how close you were. Thanks again
Paul
Just pulled the primary clutch apart and found it has the following:
8FA 00 weights with steel rivet in the top and looks like an alu in the tip
16.5 mm rollers
Orange silver orange spring
I have a set of 14.5 mm rollers coming
How will the OSO spring work or should I switch. I have a Pink Pink only 2 marks on it from an SRX. I'm thinking it's pretty sacked out though.
According to the spec on TY the weights are'nt supposed to have any rivets which might explain why I'm not getting the RPM's I need.
