need clutch help
rkeener
I have a 2009 xtx and i want to lower clutch engagement. dont have much $ (bad year) but i do have a set of 15mm rollers. stock is 15.6. What spring should i use?Will doing this have any negative effects?
A wise man on here used to recommend 14.5 mm rollers, stock springs, 3 engagement shims and a straight Yamaha 47 helix....you should be fine by just adding the 15mm rollers with stock springs..the helix is just an added kick.
