I have a 2004 worrier and i switch the track out.I changed the drive gears and put the new skidoo ante ratchet drivers on my sled. I bought a six pitch track to. The drivers are centered in the skid but the the right driver is rubbing on the right of the window of the track in front I adjusted the track both ways right to left i just don't now what to do .I Just want to tell you guys i had the drivers and the chain case and tack out and together 3 time so i am getting feed up with it so what should i do.
Len Todd
You need to be more descriptive regarding what you mean by "rubbing on the track!"
longshot
skidoo anti rachets
tofast- Measure center to center distance on the windows. Then measure center to center distance on the drivers mounted on the shaft. If the difference is 1/4 in. larger on the track and the left driver fits fine, then move the right driver towards the left driver by 1/4 in. and that should put both drivers in each window center. I'm assuming the track was in the center of its range of adjustment when the left driver was centered. Don't know if you did the mounting or measuring, but you will need a press of about 2,000 psi to move the drivers on the shaft. Even if you did not mount and measure first, do it now so you know what it should be. Good luck.
longshot
tofast- sorry about the confustion, I meant to say if the c/c distance was larger on the drivers, not the track.
