NEED STUDS
kinsound
Southern New Hampshire USA!!!
Looking for a good deal on 144 1.075" studs...Woodys or Studboy or even Mack , aluminum backers, nuts for an 03 RX1ER....Anybody dealers on here have good deals?
Call the Speed Shop they advertise here and have great service. I got my picks from them and his prices were great.
with all of this talk of tuds lately,
do u need a speical bit 2 drill the holes or just a normal wood bit and if so where can u buy them
There's a bunch of different ways;
1) normal wood bits - makes a scraggly hole, but that gets covered by the stud and backer plate.
2) hole punch - makes a clean hole;
3) MELT through - stinks like all hell, but this is probably the best way to do it since it seals the rubber and cord together. To do this use an appropriatly sized shaft (maybe a screwdriver), and a regular plumbing torch to make it hot.
GO TO THE LOCAL SNOWMOBILE ACCESSORY STORE AND GET YOURSELF A WHOLE CUTTING BIT. THAT WILL CUT THROUGH THE TRACK AND MELT THE CORDS AND RUBBER AS WELL. IF YOU USE A REGULAR DRILL BIT YOU RUN THE RISK OF PULLING AND DAMAGING THE CORDS IN THE TRACK(NOT RECOMENDED).
thax
i like the melting one...
how long does that take and how much butane will it take (not that it matters, just wondering)
Plumbing torch runs on PROPANE. Butane torches are toys and aren't nearly enough power for this job. One $1.20 portable tank and $8.00 torch will be way more than enough. If its not freezing it'll go pretty fast since you just poke the rod through the track. The nasty part is putting the shaft back into the flame when it cools down all covered with melted rubber.
I would caution you though.... make sure you have some kind of template to fit between the lugs to guide you. You can make something out of a strip (or a few strips for different patterns) of wood.
IMHO The one that is made for cutting holes in the track for studs is not very expensive and it is very fast to use, Just chuck it up in your drill and it is practically bing bing bing.
LB, thax for the info but i'm sure butane is more powerful than the propane one, got both of them up the shed and i do a bit of plumbing work around the house and cabin
i'm a do it your selfer....like 2 see the day i pay someone 2 remolded my house
thax
sorry LB,
got the yellow and black cans mixed up
anyway, i tried that yesterday on a old track up in the shed and it went through so ez......way faster then drilling i would assume...only had to poke it and it went right through and before i knew it i had a half dozen holes made on a track that never really had anything wrong with it
thax
i also made a jig yesterday 2....got bored
:rocks:
Auskins said:
sorry LB,
thax
:rocks:
lol. Amazing how much fun destruction can be ;)
