gary
- Feb 26, 2012
I have a 2010 nitro xtx i need a heavier
suspension i am about 300 with gear i have a chance to buy a 2009 venture skid i was wondering if the springs and shocks would fit under my skid and would they be a heavier suspension . thanks fore any help
ALuCsRED
2010 FX Nytro XTX rear springs
Part 64
8HL-47473-00-00 SPRING, REAR 1
Part 65
8HL-47474-00-00 SPRING, REAR 2
2009 FX Nytro RTX rear springs (including optional springs)
Part 67
8GL-47473-00-00 SPRING, REAR 1 (K=1900NMM/DEG) | AP
8GL-47473-10-00 SPRING, REAR 1 (K=2100NMM/DEG) | AP
8GL-47473-20-00 SPRING, REAR 1 (K=1400NMM/DEG)
Part 68
8GL-47474-00-00 SPRING, REAR 2 (K=1900NMM/DEG) | AP
8GL-47474-10-00 SPRING, REAR 2 (K=2100NMM/DEG) | AP
8GL-47474-20-00 SPRING, REAR 2 (K=1400NMM/DEG)
Looks like the XTX has the 1900 NMM/DEG springs on from the factory (comparing part numbers), and you acan order stiffer 2100NMM/DEG springs (optional for the RTX) since the original XTX spring part can be used on the RTX (same part numbers). The price from the dealer in the states that I use is less than $60 per spring.
Another option is to buy for the rear suspensions is the Hygear torsion spring spacers (http://www.hygearsuspension.com/Product ... rings.html). They stop the springs from twisting, effectively making the springs stiffer.
Part 64
Part 65
Part 67
Part 68
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
I did the Hygear spacer and X-Clicker 4 sided spring cam. I'm almost 300 suited up and that config makes my sled buccaneer impossible to bottom.. $100.00 bill, total cost.
gary
- Feb 26, 2012
ok im still not sure if the 09 venture will fit mine but i was told here that the big boy springs were 337 a side thats why i was looking at other options .
gary
- Feb 26, 2012
ok i was just wondering if the 09 venture gt has the same but stiffer springs on the rear as the 2010 nitro xtx , sory fore my confusion
YamaHammer71
Ever look at Star Suspensions? They have a kit for the XTX that takes the squat out of it and allow it to use all of it's travel. I'm 300+lbs suited up, and I have an xtx, and will be looking getting their kit, plus their 5-sided torsion spring adjusters. Might send them the shocks too, but I'll wait till after I've tried out the other stuff first.
