mshabaz
- Aug 16, 2006
Im new to fox floats. I have a 2011 se and trying to figure approx what pressures to run these at. It's a completely different feel from my old Olin's. On the 06
RollRite
- Dec 16, 2004
- Pickerel , Wisconsin
- 2011 Apex
I'm 200 lbs I run 55lbs in front and 160lbs on the mega float.
RollRite
- Dec 16, 2004
- 2011 Apex
You to have the weight off the shocks also when you check.
mshabaz
- Aug 16, 2006
Ok I'm about 200 as well. Any bottoming issues? Or does that seem to give u good bumps and cornering
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
205 lbs + Gear
62 lbs up front, 160 lbs in the rear seems best for me. Limiter up 1 hole.
Sno Trackers [semi aggressive only on 2011 Apex's] and 102 Megabyte 1.325's
up the middle.
up the middle.
RollRite
- Dec 16, 2004
- 2011 Apex
My limiter stap is at stock
RollRite
- Dec 16, 2004
- 2011 Apex
