hey guy's thanks for the helping me buying a new sled,got a 2006 apex love it,just looking it over the secondary clutch has a little slop if you pull it in and out to you, is that normal or does it need a new shim or a kit thanks for the help
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
That normal.
yamahahaha
perfectly fine and normal, u will love the sled
SharkAttak
floating secondary which is normal, so guys make them fixed
how a about the brake caliper should a little slop,thanks guys
how about the primary should i lube the fingeres,gonna buy a new belt what should i buy,thanks for all your help
- Jun 28, 2004
- Clinton, Wi.
Yes on the brake rotor, and no on the clutch. I've got 12,000 on my Viper, 8500 on my XTC, and 4200 on my Attak. All with no lube and normal cleaning each season.
shanksyamaha
Yup, sled clutches are dry, not like atv clutches. No lube on the weights or rollers, just lube your bearings good... Spend some time and read through the FAQ on this site. You will learn so much..
IMO. The most important points to keep an eye on are the arms and rails on the rear skid and make sure to grease your driveshaft and jackshaft bearings as well as wheel bearings in the rear skid. Should hold up well for ya..
can anybody point me in the right direction to get to the driveshaft bearings and jackshaft bearings any easy tricks with out a ton of disassembly,thanks for all the help
sledneck22
This is the link to the bearing regrease. Use the search wizard and you can find lots of great info!
