Newer Apex Exhaust
thor452
Because I can
Shawano,WI 54166
2012 Apex XTX 2017 Sidewinder LTX-LE
Hi guys I have a 2012 xtx and I am wondering as i havent seen much at all about the donuts. are they a problem on this set up with the exup in there or are they lasting beter now? If anyone has worn out a set could you post what mileage you were at when it went out.
I replaced mine after 3 seasons and 8,600 miles, they weren't in that bad of shape, just showing wear on the bottom of the donut. Should be good now for another 3 years.
You don't want to replace these EXUP exhaust due to broken flanges, the EXUP is over $2k to purchase, yikes!
Kaz
Thanks KAZ yes thats my worrie with them do they take the same size donuts as the 07's did. has anyone had to change them sooner then that? Did you just go in and look at them as a pm or was the sled getting loud and or back fireing?
They are not the same size as the 07, larger dia. pipe on the 11's and newer, I believe they are the same size as used on the 3 cyl. nytro's.
I just check them at the end of the season, replaced them twice on the 07 already, but that's after 13,000 + miles.
Kaz
