No headlights, tail, Dc Socket power
Age
58
Port Perry, Ontario
Canada
2010 Vector ltx GT
2010 MXZ X 1200
LOCATION
Port Perry
Sled runs but today I lost everything, got home it all worked again. Went back out to shop and again will start but nothing works.
Check fuses over fan and apart from heated sheild all is well.
I suspect bad ground or a bad power control relay.
Does anyone know where the grounding blocks are located?
Can anyone point me to the location of the power control relay?
Many thanks been tinkering a while now and figured I would ask
I figured it out, I located the relay, In front of my left foot. Switched it with fan relay and everything worked. Switched it back and problem returned (always turn problems off and on to confirm you found root cause)
Big relief I hate electrical issues
On a side note, I have been having issues where fuel pump keeps running unless I hit the kill switch. Wondering if it might be related.
it could be the pump relay is sticking in the run position.
I will replace power control and see if it persists. If it does I will replace. Either way I will update post. Hopefully it helps someone at some point.
