snopro442
- Dec 10, 2007
- neenah wi.
- mod 08 nytro, 2-2007 phazers and a 2010 sno pro 500 speedwerx exterminator. new 2014 nytro for towing the snowcoach. 2015 Viper mpi turbo
I need to remove the ecu from my nytro to send it in for the hot grip update. I have the sled in storage about 45 minutes from me. I would like to know if I need to bring any tools with me or is it just held in with a rubber strap? any help would be great and save me a lot of traveling if I don't have the right tools. Thanks.
R00STER
- Mar 3, 2013
- Timmins, Ontario
- 2013 Nytro xtx 1.75
It's held in with a couple of small bolts, around 8mm I'm thinking off of the top of my head. Just take a small socket set with you and you will be good to go.
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Yes 2 small bolts and a strap. Watch out you don't drop the bolts down into the engine cavity!!
Pete
Pete
snopro442
- Dec 10, 2007
- neenah wi.
Thanks for the help.
NH_Nytro
- May 15, 2011
- Colebrook, NH
- 2008 Nytro
2007 Rs Vector
post up how the update works, I have been thinking about that as well.
snopro442
- Dec 10, 2007
- neenah wi.
Will do,
