mach9
Machine primary for overdrive...
Anyone done this? Is it worth the hassle or is it a waste of time for more top end?
I did mine late last year. It seem to have more top end but all I did was race up boyne mountain with it. It wasn't topping out like it used to. If u do your primary u might wanna do your secondary too.
TurboJamie
Hauck speed sheve, get one.
Beenba
- Feb 16, 2011
- 2009 Nytro XTX
I have my clutch disassembled at the moment to fix the rattle issues (putting in some new o-rings)...at the same time I will be machining my primary for OD. I dont like that single sheave idea...i'm not sure how they have designed it, but when I do my overdrive setups I don't only just allow the clutch to close a little tighter, i actually reface the entire angle of both sheaves and change it by a few degrees.
I'm doing the same thing as what we had done to my 700, and it was amazing difference for that sled...seeing as Yamaha clutches haven't changed in over 20 years, I'm confident it will be awesome on the nytro too!
mach9
Thanks guys, I'm looking at options.
There were a couple Vectors out there last year that surprised me.
shadow44
Beenba said:I have my clutch disassembled at the moment to fix the rattle issues (putting in some new o-rings)...at the same time I will be machining my primary for OD. I dont like that single sheave idea...i'm not sure how they have designed it, but when I do my overdrive setups I don't only just allow the clutch to close a little tighter, i actually reface the entire angle of both sheaves and change it by a few degrees.
You should slip by and do your neighbours clutches aswell
RIKMAN
- Feb 21, 2008
- Val d'Or, Qc
- 2020 Srx
poleclimber said:I did mine late last year. It seem to have more top end but all I did was race up boyne mountain with it. It wasn't topping out like it used to. If u do your primary u might wanna do your secondary too.
As for the secondary, If you're using the stock helix, get it machined (remove the inside flush to the bushing). If you're running aftermarket helix they are already machined.
bluesrxman
- Aug 9, 2004
- Lakeville, In
- www.midwaydental.com
How mutch are you machining off the primary?
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Ya I should be in Ontario over X-Mas visiting family. I could easily swing by with some Grogg and and my primary LOL!!shaddow44 said:Beenba said:I have my clutch disassembled at the moment to fix the rattle issues (putting in some new o-rings)...at the same time I will be machining my primary for OD. I dont like that single sheave idea...i'm not sure how they have designed it, but when I do my overdrive setups I don't only just allow the clutch to close a little tighter, i actually reface the entire angle of both sheaves and change it by a few degrees.
You should slip by and do your neighbours clutches aswell![]()
Beenba
- Feb 16, 2011
- 2009 Nytro XTX
Haha, well lets see how it works out before I start messing with other peoples! The only thing is I havnt rode the sled stock yet, and I will likely be machining it before I get a chance to ride it..so I wont have much to compare too! Maybe I should wait...
This mod works.I know a lot of guys running in the 120-124mph range on radar with apex's with the ripsaw and set up for trail riding and geared down a tooth.
Here's a link how to do it.
http://www.ty4stroke.com/viewtopic.php? ... ght=flores
