Just wondering who has put O2 gauges in? What kind of sensors did you use (heated or unheated) and where did you put the sensor?
spray25
Heated sensor from autometer. Replacement sensors are available from NAPA. part #OS302.
Buckeye
- Lakes Region, NH
spray25 said:Heated sensor from autometer. Replacement sensors are available from NAPA. part #OS302.
he answer to the second half of the ? is? Where?
peteracing
AFTER TURBO, AFRAID THAT IF IT BREAKS, TURBINE WILL HAVE TROUBLE
DIGESTING IT
DIGESTING IT
spray25
Bender puts the sensor just before the turbo.
Buckeye
- Lakes Region, NH
peteracing said:AFTER TURBO, AFRAID THAT IF IT BREAKS, TURBINE WILL HAVE TROUBLE
DIGESTING IT![]()
HMMMMM!!!!! That solves that problem.
:ORC
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
Bad idea. Nothing like a $20 part taking out a $1000 part. Not knocking anyone, but it isn't any more difficult to put it downstream from the turbo than it is upstream, and you eliminate a possible failure point.
Just my opinion...
Just my opinion...
Turbo Tim
I put mine in after the turbo( bender) in the bend in the pipe , now all i have to do is pull the exhaust side cover to get to it .
SuperDave
- Aug 28, 2003
- Sicamous, BC Canada
- www.powderlites.com
