O7 Attak; Wheel's with 6205 bearing
kenbar
North-Eastern Canada
Will idler wheels with 6205 bearings fit onto the 07 Attak with no modifications? Which size bearing fits for the rear wheel? I have been reading posts and it is a bit confusing. I sourced idlers that are the same width with 6205 replaceable bearings for idelrs and 6004 bearings for rear.
Ive been running wheels with 6205s since day one on my 06 Attak. Because the bearings are wider, I had the rear post machine to recenter the wheels. You also need longer bolts to hold the front ones on.
