travism
i have an 06 apex mcx kit with head shim i run c-16 motor has 50 miles
compression is 130 130 130 140
at 8000 rpm it starts spitting oil. it spitts tell the oil light comes on then stops. i also stopped the motor let it sit fire it back up and oil light is off. but it comes back on in a few min.. from what i have read the rings would be bad that is not the case here. i also tried to oil the rings down i have not taken it out to see if that worked
could the oil sensor be bad?
should i run with the oil light on that seems low to me.
any help would be great thanks
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Oil coming out breather is never good. I'd say you better do a leakdown. Looks as though you may have 3 bad slugs. There should be no oil coming from breather at anytime with a healthy engine.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
KnappAttack said:Oil coming out breather is never good. I'd say you better do a leakdown. Looks as though you may have 3 bad slugs. There should be no oil coming from breather at anytime with a healthy engine.
I second that!
vapor only, maybe oil vapor, but no oil.
Skydog
yea sorry buddy, pull her down...
Leakdown is the only way to really tell sounds like detonation and its blowing by the rings. Hopfully its just the rings and you haven't ovaled the cylinders. Sorry
copo427ss
whats your ring end gap. did you check them? if they are to big then you will pressurize the bottom and blow oil out of the breather and your compression will read ok.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
take leak down on all piston positions with closed valves, this will probably tell you if cylinders have damages.
about same leak down across the stroke probably indocate no cylinder damage while big variation across will indicate ovalisation/chiped/tapered
travism
im getting a leak down tester today.
found bad vacume leak on throttle bodies would this cause case presure?
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
no
