Boston RX1
I need a sway bar with the mounting brackets. Does anyone know if a MTX unit is the same as mine? I have a chance to buy one used and would like to know if it will fit.
The MTX should fit as long as the brackets and bushings are included. There are 3 diiferent bar sizes on the various machines... 13 14 15mm.... stock is 13mm on the SE.
Boston RX1
Thank you Brian. If I have a choice on what to get, which size should I choose?
phatkid
if u need a stock swaybar off of a "se" I have one with the hardware avail....
pm me and ill set ya up
