Convert
snowsweat
Thanks! These maps are incredible! Does anyone know how I can get these maps into my handheld GPS or even onto my computer?
Convert
The trick is finding the actual image with the interactive java versions thats a little tougher. The ones that are PDF files you can easily right click on the link and click save target. Another way to capture the image is to get the portion of the map you want on the screen and and use print screen to copy it and then paste the image into paintbrush crop and save as a jpg or bmp file. If your going to do it this way set your resolution as high as possible that way the image will be larger and can be easier read in the lower resolutions and still have good legibility. Here's an example.
Mikey
If anyone needs any guidance in the Thunder Bay , Atikokan, Nipigon and Geraldton areas PM me as this is my backyard and know it and the trails very well.
montinj
The trail map on the OFSC webpage are not always gps.
The OFSC web maps are not necessary accurate. I should know as a club president, I have tried to have them correct our section of trails on the webpage for the last two years.
The maps should be consider approximate. Most clubs are trying to GPS them but it will take time.
