Scooter02
- Nov 26, 2007
- Oak Creek, WI
- Yamaha Viper LTX LE
I picked up a black Apex GT for my wife awhile back. I am planning on dying the grey stripe on the seat, like I did on my red GT. I would also like to paint the exhaust covers from silver to black. I checked out some spray bombs at the hardware store that worked on plastic. Same for clear coats. I know that prep is the key to a good paint job, what would people recommend?
theCATman
- Feb 19, 2007
- WI
- Yamaha
Get some scuff pads. Green ones can be had almost anywhere.
Scuff, wash with dish detergant to remove any oils or grease, dry, & paint with MANY light coats.
I have had excellent results with the rattle can plastic paints. I've painted plastic lawn/deck chairs, faux window shutters, ATV plastics, & the hood vents on my Apex.
If possible, get a fan tip can. Much easier to get smooth even coats.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
I painted mine a few years ago.
They were red and I painted them white.
I scuffed them with scotch brite. Degreased and Washed them pretty well.
I used rust oleum for plastic. No clear coat.
They held up pretty well some minor scratches but pretty rugged overall.
My biggest gripe would be that the seat rubs on them and I just can't keep paint on the areas the seat rubs on.
I will be redoing the foam and recovering my seat this summer so I plan to trim the seat pan a little to stop the rubbing.
ranger1
I painted my RTX's from Yellow to black. Used 400grit wet/dry sand paper, cleaned with alcohol & used automotive spray paint in a can. You won't have to prime it if you are going on top of the old paint.
doubler8
- Mar 11, 2013
Can you explain the seat dye process?
Indy
doubler8 said:Can you explain the seat dye process?
rattle can for vinyl, tape off the area and lightly scuff the vinyl.
Indy
ranger1 said:I painted my RTX's from Yellow to black. Used 400grit wet/dry sand paper, cleaned with alcohol & used automotive spray paint in a can. You won't have to prime it if you are going on top of the old paint.
x2 except I would prime with adhesion promoter, and probably start with 600 grit.
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
Look for SEM brand vinyl dye. It's available on line. I suggest using the dye and seperate primer recommended by SEM for best results.
My dye job was done using these products and has held up perfectly for 4-5 years now.
Just like normal spray painting. Clean and tape off the area. Apply primer and dye as described on the spray cans. Done!
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
RTX said:doubler8 said:Can you explain the seat dye process?
X2 on the SEM-works awesome and holds up excellent, prep work to clean clean clean is important.
