CCCT
- Jan 9, 2017
- Barrie/Sudbury/Muskoka
- 2007 Apex
2009 PhazerGT
Noob question and not near service manual i have. But for removing exhaust, dropping the skid and letting it hang is the easiest approach i assume. Do i just remove these 2 bolts on each side (see pic) and voila? it'll hang and give me access under the tunnel ?
any precautions I need to do or is it as simple as it sounds, remove 4 bolts, then for re-install, simply lift skid back up and install bolts? I only have 2 hands and no proper lift so I dont want to be struggling too much.
thanks
thanks
Winderallday!
- Dec 4, 2007
- SW, Ontario
- 2018 Sidewinder DX
32 is the aluminum shaft that goes through the swing arm, 35 is the bolt that goes through the drop bracket.
To relieve the pre-load to remove one end of the transfer rod without the benefit of a lift/stand, you will need someone to compress the suspension from the top side sufficient to remove the bolt from the one end of the transfer rod mount.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Apexallday is spot on.
CCCT
- Jan 9, 2017
- 2007 Apex
2009 PhazerGT
Thanks guys. Kyle.... Enjoy your trip ... Hopefully I can get out with you Nels again....otherwise I'm buying a damn boat and fishing up north it is.
